I Have What I Think Is A 1976 Johnson 70 Horse.. There Is No Tell-Tale ( That Stream Of Water Out The Bottom Of The Side Of Cowl Base).... It Looks As If There Was Never One on This Motor..Which To Me Is A Bad Idea... How Do U Tell When Your Impeller Is Going Bad..Hmmmm... Is There After Market Tell-Tales i Can Put On This Motor ? Or Maybe A Water Pressure Gauge.... I Have Looked All Over The Motor For A Tube, Anything To See If It Was Blocked Off By Someone Else.. But There Is Nothing.... Did Johnson Make Outboards With No Tell-Tails?? Thank You....
