Yamaha 6Y8-83500-11-BK Digital Multi-Function Boat Speedometer/Fuel Gauge Not workin
lakelane1
Our speedometer is not working correctly. It goes back and forth between 24 - 26 MPH even when the boat is not moving. Any thoughts on how to repair or what could be wrong?
99yam40
Re: Yamaha 6Y8-83500-11-BK Digital Multi-Function Boat Speedometer/Fuel Gauge Not wor
maybe the tube is plugged
disconnect from back of gauge to see if it will go to 0, if it does the look for where it is blocked.
Probably at the lower unit pick up
EMC 1810SS
I had the same issue. I had backed off of a beach. I pulled the tube and blew some air thuough and now it works fine.
lakelane1
Thanks we will try that, it's probably all it is
