1983 Johnson 70hp - Do I need to re-set the timing?
carpedium
Hello,
I am in the process of waiting on a new timer base for my motor. I pulled the flywheel and everything looks good under there - top main seal is in good condition, etc. When I put the new timer base on, do I need to find some place with a test wheel and o/b tank to check the timing on this motor, or will it "probably" be ok?
Any help would be greatly appreciated.
Thanks.
carpedium
Re: 1983 Johnson 70hp - Do I need to re-set the timing?
Should also mention that the timing seemed to be OK before I tore it apart.
carpedium
And that the new part is a used part instead of a new cdi unit.
boobie
How do you know the timing was okay before you tore it apart ??
carpedium
It ran with no problems
carpedium
Bump. Nobody familiar with replacing a timer base?
carpedium
alright, well... I will update with my trial/error experience, since one of you may have to consider this in the future.
carpedium
Seems I am the only one with timer base experience now! No. You do not need to redo your timing.
Blacksting
it seems to me you took on a very complex and critical task . ,.... and even with Joe Reeves' legnthy and absolutely perfect instructions , i wouldnt attemp it at the risk of misaligning something unless i was sure it was a link and sych job . too many variables to overlook . ,......but what exactly do you mean ? did you do the job or not ?
durban
Master Chief Petty Officer
providing you have not fiddled with the stop screw under the flywheel & the screw on the linkage , ive taken them on & off heaps of times & all sweet
carpedium
Getting the flywheel off was the hardest part, other than that its probably a 15 min job for the 1st timer. Very easy.
Yup, I did the job. The answer is that you can change your timer base without having to re-do the timing.
schematic
Hello,
Thanks.
Agree with Boobie....
I always recheck the timing after replacing the timer. Who's to say that all timers are electronically and mechanically equal. Who's to say is was correct before? Just because it appears to run sweet doesn't mean it won't burn pistons.
If you're up to changing a timer, the task of rechecking the timing is well within your abilities.
carpedium
Thank you for the additional info. I'll see if I can get a loaner timing light and reset the timing via the reeves method.
boobie
Good point Schematic. I've always checked the timing when ever I replaced any ignition component. They can all be different.
