Which side to tie to dock in a wind?
ricohman
I was out yesterday and tied up to my brothers dock. I ended up tying on the side opposite to the wind as the boat wouldn't be bouncing against the dock. But if a rope came loose the boat would swing.
Which side is better to tie to considering the wind? I was only tied up for a few minutes to drop off passengers but if I was to tie up overnight is it better to have the wind keeping the boat against the dock?
Re: Which side to tie to dock in a wind?
Ayuh,... I prefer the boat is blown Away from anything Solid....
'n with a bow line, a stern line, 'n 2 spring lines,... It Ain't goin' nowhere....
ajgraz
I always try to tie up with the wind (or current) pushing me into the dock. If I lose power/shut down while approaching, or if as you say a dockline breaks, the wind will work with me, not against me.
But I have a very small boat. If my boat was big enough to actually damage a dock, or to take serious damage from ramming a dock at low speed, I'm not sure which way I'd go.
Home Cookin'
you tied up correctly. Your boat should not be against the dock. You can't worry about "if a line comes loose" any more than "if a through-hull fails and the boat sinks." You just have to do your best to have the right equipment and know how to use it (in this case, know your knots). And so what if the boat does swing in the unlikely event your line comes loose in the few minutes you are there?
Bond-o makes a good point, that redundancy can be important. However, I would not have 4 lines out for a few minutes' drop off. When I tie up in preparation for a storm, everything is triple tied.
It's all situational. A short-term tie-off is not the same as an unattended overnight. Remember, things can change--in your case, wind direction, and maybe waves. I have to deal with tides and currents as well as wind. Also, what if? if I am alone in the marsh and my boat is my only means of transportation, I will be a lot more careful on tying, than if I have options.
There are also ways to tie a short line and a long line when you have a current/wind parallel to the dock, so your boat stays off.
It is usually better to approach your dock or other object against the wind/current, for one thing, so that if you lose power you won't hit the dock. It is better not to have the boat touching any structure, than to use fenders or rely on your rub-rails.
H20Rat
If I'm tying up for any length of time, I'm always tying up down wind. Don't really want the boat bashing into a solid structure. If I am just dropping people off, I'd rather have the wind blowing me towards the dock, and not rely on passengers to assist in docking in any way. (of course, this is assuming a gentle breeze... 40 mph gale force wind, and hopefully I'm not on the water, but if I am, I'm not going anywhere close to the upwind side of the dock.
ricohman
Down wind it is. I am going to rent a slip at a marina for an overnight and I know that the winds can change. So I will use fenders and 4 ropes minimum.
QC
I agree, but FWIW I had a situation a few weeks back where I chose the opposite. The wind was blowing somewhat hard ashore, and the dock was just off the rocks and abeam to the wind. I only had one shot at it each time, and I was often alone, so I chose to use the wind to "catch" me in the slip. If I had chosen the other side and had an issue I would've quickly been on the rocks or against the adjacent boat. In this example I chose leaning on my fenders as a small price as compared to a date with the rocks, or an encounter with my slipmate :eek:
shrew
If you're going to be in a slip then that is different. You can tie bow lines to the pilings on both sides and stern lines to the pilings on both sides. You should still be tying spring lines as Bond-O mentioned. This would keep the boat from touching anything on all sides regardless of which direction the wind is blowing.
Outsider
Ahhh, fenders! Now there's a novel approach ... :facepalm:
ricohman
You don't recommend fenders if the boat is left overnight?
Home Cookin'
you shouldn't need them and should look for a way to tie up so you don't have to have them. But having them there may give you some sleep-better comfort.
get the guys at the marina to help you with tying up; we can't do it from here.
Glad to see the boat in the water after what you've been through!
ricohman
I am going to be reading and practicing some knots before I do this. Lots of great sites with info.
