Re: Stringer Material
R Socey thats what i picked up today at lowes, Thanks for the input. YD There is a center stringer and ive gone with oak for that. il set up some pictures.
So in the center is the single stringer which is already removed. On the left is a cut into the glass which completely exposed the old wet plywood/stringer, this can be thought of as the hull floor joint i suppose. On the right of the picture i have yet to cut the remaining glass which covered the old floor/plywood. Basically the floor was a piece of plywood laid over the center stringer glassed over. The ply was cut short maybe 3-4 feet from the transom and 2 extensions continued to the transom.
