Hey guys, it's been a while since I was here but need some help. I have searched for a month and not had any luck with my problem. I have owned this 1999 5.7 Mercruiser for 7 years and had no issues other than a starter two years ago. Four weeks ago on a two day camping trip, my boat failed to start on the second day. I assumed it was the starter again, no big issue. I took the starter off to find that there was nothing wrong with the starter. I am not a boat mechanic but to have a pretty broad knowledge of engines and have built several. With no starter problems I tried turning over engine with no luck so I pulled all of the plugs and cranked. The #7 cylinder was full of water and #5 looked like it may have spit a little spray. I have never had a miss from the engine and its never been hot, oil pressure runs about 40. Anyway, I pulled the manifold and gasket off since that seemed to be the most common problem. Everything looked good and I filled the riser up with acetone as I had read and replaced the gaskets. I also did a compression test on all cylinders on the left bank. There were a couple lower than I would like to see but were around 100, definitely not the source of my water.So, I changed the riser gasket and put it all back together. I checked oil and no sign of water in the pan. So, I fired it up with muffs and let it run. I even let the muffs run without the engine on to see if it filled a cylinder. Nothing. So, back to the water we went. I have three kids that ski and wakeboard so it gets alot of start and stop on the water. We had perfect trips for three weeks, usually two days per weekend. Yesterday, after boating all day Saturday and half of the day yesterday, it hydrolocked again. This time, there was water on both banks of the engine. I blew all of the water out and it fired up and ran perfectly..... I am at a loss. How is water getting in both sides? It is running perfectly. I have avoided quick stops(which I have never worried about). It isn't even consistent with setting a long time without being started. Yesterday it had been shut down for maybe ten minutes and filled up at least four cylinders. I do know that about three years ago it ran a little warm one day so I decided to change the impeller. WHen I got it apart there was a small rubber piece that I didn't recognize on top of the impeller. I removed it and changed the impeller and have no issues for three years. After looking at several schematics over the last month I realize that it was a flapper from the exhaust. I have purchased the new ones and will be putting them in tonight but I don't believe that I ran for over three years and never had this happen and then suddenly it backed up through the exhaust twice in a month. I have searched and searched and have seen similar problems with other people but never the solution. It is fresh water only and the exhaust manifold and risers look brand new. We have rented cabins next week on Kentucky Lake and the vacation will be ruined without the boat so I am struggling to find the problem. Any help is appreciated.
