riveraftin
- Mar 22, 2009
- 11
90 Merc Outboard 1989 ? I started having an issue of the motor shutting down after running full throttle for a few minutes. I found that the primer bulb was not staying full and a cracked 3inch line. I think it was a vacuum line. I replace the fuel line to and from the primer , the cracked line, and decided to put in new plugs. When I started it I got a few good backfire pops, something new, but then it started and continued to pop every now n then.
I took it out and it now stays running but I don?t have any power at full throttle and idle is ruff. Could the pops I had when I first started it, have caused the coils to go. I know a bad coil can cause some issues, but not sure what.
Thanks
Back yard mechanic
Thanks
Back yard mechanic
