marcoalza
- Aug 22, 2010
- 643
There might be a simple remedy/explanation for this but I am confused;
We?ve just moved villa in the same area.
3 floors, 7 Air Con controls/thermostats in total.
Been having a bit of a nightmare as trying to find any sort of expert in any field in this country is a task.
Whatever the query, the stock answer is always negative.
Anyway, AC has been a mess as soon as we moved in.
Outside temp here is 113f at the moment so it's no joke.
Now starting to get somewhere as the engineers have been here daily.
One thing I cannot get these guys to understand is an issue with some of the room stats. I?ll set the control at 23c. That?s fine, AC comes on and off as it should most of the time. Until?.it won?t click on and the room temp for sure is around 26c. If I press the button which shows the current room temp this displays 18 or 19 (which the room definitely isn?t) which is why the AC wont fire up.
If I override the stat by clicking on manual, within a minute the room temp display shows 25! Then the AC is working OK for a while then we start all over again.
Now I?ve said that the control unit in the room is faulty but they are having none of it. What baffles me is that 3 other rooms have the same problem.
Can they all be faulty with same issue? Villa was built in 2006.
Any ideas before I murder someone?
