grindinglarrypro
- May 25, 2012
- 3
What is a good fuel treatment to get rid of water in the gas tank.
Remove the tank, drain water, replace tank. Snake oils increase the profits for Snake oil salesmen and only work on snake infestations.........
If I had that problem, I would remove the fuel gage sender and use a siphon hose to "vacuum" the tank out a few times
That is what I did with the tongue cranked way up, but hard to get it completely dry and spotless. Was moving the hose port to starboard and tried to get all that I could.
Not sure how long Larry's fuel has been in the tank, so more info might help us help him.
Looking forward to seeing more of that truck project Rick.
Having problems when decelerating. Engine speed fluctuates up and down and i think the #7 cylinder has a fouled plug. When i first start and accelerated it was running good was at 4200 rpm in smooth water on the Hudson River then i encountered a lot of boat traffic and waves and that is when the engine lost power upon deceleration. I was thinking it could be a problem with water in the gas. Just bought boat and it had a quarter tank in it and since have run about 25 gallins of 93 octane . I see there is deceleration valve on the engine or could the accelerator pump not be adjusted right. Plan on doing acompression test tomorrow. Any help would be appreciated
When I first read you post I was thinking moisture in fuel, didn't pay attention to the words water in gas tank. You need to do what HT32BSX115 said and get the tank clean.
