My boat is a '97 Larson 206SEI with a Mercruiser 5.7L and an Alpha 1. The prop is an aluminum 14 1/4 x 19. I've never had a spare prop but I'm thinking I should get one. I thought since I'm buying an other prop maybe I would try a 4 blade. I'm fairly happy with the current prop. It's a Flo-Torq model from Mercury Marine. I would want the new 4 blade to fit the same drive hub.
The reason I might want to try 4 blade is for better hole shot and staying on plane at slower speed.
Do I get a 4 blade with the exact same pitch and diameter? Will it improve the things I want to improve?
The boat is used mainly for cruising and tow sports. We normally don't run any faster than 35 mph even though it will do 47 as currently rigged. I normally have anywhere from 3 to 10 people on board.
Thanks for your help.
