I have a 78 35 HP johnson (35EL78R) It has set for many years without use, working to get it cleaned up and going. Went to remove the lower unit to replace the impeller, can't see how to get it loose. I worked on an 85 HP motor some time ago and there was a bolt to remove on the shift lever, but I don't see that on this motor. I was told it may be a splined shaft and would just drop out - that didn't happen. I looked at a schematic and it appears to show a bolt at the top of the ship lever but doesn't show me where/how to get at it. any tips you could provide would be appreciated.
regards,
bruce
regards,
bruce
