Re: ethanol buster
i put a post on here about my boat spitting and sputtering and a few said that it was the ethanol in the gas..i talked to my mechanic and he said the same and to get something called ethanol buster..has anyone ever heard of it and is there another product that does the same thing?thanks chris
ETHANOL FUEL IS CAUSING 2-CYCLE AND SMALL ENGINE PROBLEMS WITHOUT A DOUBT. IF YOU CAN FIND NON-ETHANOL FUEL USE IT IN YOUR OUTBOARD, LAWNMOWERS, CHAIN SAWS, ETC. ETHANOL IS COSTING THESE MOTOR OWNERS BIG TIME AND MECHANICS ARE DOING WELL. THERE ARE SEVERAL BRANDS THAT HELP WITH ETHANOL BUT NONE ARE PERFECT FOR ALL PROBLEMS BEING CREATED. I USE A PRODUCT BY STARBRITE CALLED STARTRON, I BUY IT AT LOWES FOR $6.97, 8 OZ BOTTLE TREATS ABOUT 48 GALLONS. IN OUTBOARDS I HAVE SEEN THE INSIDE OF FUEL LINES COLLAPSE, FUEL SQUEEZE BULBS DISSOLVE CAUSING MOTOR TO RUN RUFF TO BLOWING UP. AVOID ETHANOL IN ALL THE ABOVE IF POSSIBLE. NON-ETHANOL IS GETTING HARDER TO FIND. IF YOU KNOW STATION THAT OFFERS IT GO TO
WWW.PURE-GAS.ORG AND ADD IT TO THE LIST BY STATE AND TOWN FOR SOMEONE ELSE TO SEE.
IN MY OPINION...I WOULD DO THE FOLLOWING NOW:
CHECK FUEL LINE FROM THE TANK TO THE MOTOR, MAKE SURE ITS MADE FOR ETHANOL USE (NEVER USE A AFTER MARKET SQUEEZE BULB REPLACEMENT) IF YOU HAVE A OLDER BOAT THEY MAY NONE USED THE ETHANOL PROOF HOSE FROM YOUR BUILT IN TANK TO YOUR MOTOR BECAUSE THE BETTER HOSES HAVE NOT BEEN OUT THAT LONG YET
USE A MOISTURE/FUEL SEPARATOR SOMEWHERE IN YOUR FUEL LINE
ALWAYS BURN THE FUEL OUT OF YOUR CARBURATOR BEFORE TAKING OUT OF THE WATER, EVEN IF YOUR GOING BOATING NEXT WEEK-END. FUEL INJECTION SYSTEM MAY NOT GIVE THIS ABILITY
USE AN ADDITIVE EVER TANK UNTIL YOU CAN GET NON-ETHANOL FUEL, EVEN THEN BURN THE FUEL OUT OF YOUR CARB EVER TRIP END
ETHANOL COLLECTS MOISTURE, KEEPING A FULL TANK IS BETTER THAN A PARTIAL, WHEN BOAT IS IN NONE USE, PARTICULARILY IF YOU HAVE A OLDER METAL TANK DUE TO CONDENSATION.
REFERENCE READING:
http://www.naturalnews.com/035205_ethanol_gasoline_engines.html
http://www.fuel-testers.com/ethanol_engine_precautions.html
http://pure-gas.org/index.jsp
http://forums.iboats.com/showthread.php?t=525608
