Re: Sea Ray 17ft 3.0 mercruiser alpha stern good engine "NO SPEED"
Me thinks it is best you be clear on what exactly happened, not just here but for yourself. Can you post some pics of the prop and drive?
Does the hub touch the drive casing now? If so stop running it and figure out what is missing in your prop mounting sequence. The hub should never touch any part of the drive. There can be an anode mounted inside the housing right there, be sure if it is there it is not broken and hanging out in the way.
If it was rubbing before then your drive casing will have some serious damage not to mention the prop or prop hub. Plus, tightening the hub against the casing would tend to pull the shaft out and stress those bearings.
