waterlogged74
- Jul 1, 2012
- 5
Hello all, new to the boating world here. I picked up a 1974 reinell with a mercruiser 888 ford 302 in it. Since I bought it I haven't been able to get it to start. the engine will crank over, but will not start. In troubleshooting, I've discovered no spark from the high tension lead of the coil. I've replaced the coil, still no spark. From reading other posts, I've checked voltage at coil: 12.38v, disconnected the tach wire, cleaned connections at starter and battery and all other connections I could see, checked the timing from no. 1 at tdc although timing wouldn't have any affect if I can't get power to the dist., all to no avail. I've been known to be slightly mech inclined, but this is driving me absolutely nuts. any suggestions on what I should look for will be appreciated.
