whitelightning530
- Jul 5, 2012
- 6
So i will try to include as much detail as i can as to what ive done so far. I bought an 89 seaswirl sierra classic with a blown up 4.3 motor. Engine is a 94 vortec motor that had been swapped in ten yrs ago or so. The engine had somehow broken a ring in cyl. #2 and the piston melted/came apart. I rebuilt the motor and it idles perfect. Compression test shows 170 across the board, vacuum was at 20 in hg, all seems good. Anything above idle it misses, sounds like running on 5 cylinders almost. I set the timing at 8, put new plug wires, plugs, cap and rotor, had the coil and electronic spark advance checked and they were good.i eliminated the ignition system. I did the test of running boat with filler cap open, no change. Ran it up and dripped extra fuel into the carb while running, no change so i dont think its a lean issue.. it has older gas that had been stabilized but i am going to put new fuel in today, and i am running with no thermostat right now also until i buy one so boat isnt going over 100 degrees..also getting a new water separator filter today.. im stumped as to why the misfire??
