Re: Installing new trailer bunks
Thanks again for the input y'all. The only reason I want to put the bunks on edge is so that I can make them a bit longer. The flat bunks are in good shape, but drooping a bit at either end and they don't quite go far enough back. As a result, there's about 12"-18" of the boat and the motor extending past the bunk in the rear. It's only a 14' tinny with a '66 20 hp (approx. 80-90 lbs.), so it's not super heavy, but I'd like to be able to support the transom as best as possible. I figured setting the bunks on edge would allow me to make them a bit longer to support the back of the boat. I thought about simply pulling the boat further forward on the trailer, but I don't have enough tongue for that. Thankfully, there's no issue with transom flex, or anything like that, but I'd like to err on the side of caution and keep it that way. The good news is that the bunk brackets I have can/will hold the boards in either orientation.
I wish I could help with the weather. After the tropical storm, which we kind of needed, we're back to our normal, daily monsoon pattern; 95-100 temp with 80-90 humidity, torrential rain for about 45 min around 3:30 in the afternoon, followed by steaming roads and
fizzy hair (if I had hair). Rinse and repeat for the next 3-4 months.......
