Re: 1968 Type 1 Out-drive Gimbal Ring Tilt Switch Needs Fix
Thanks for the detailed reply on your fix to the tilt switch. The red rubber cover on mine is hard as a rock and the top of it fell off. Inside has some corrosion but was able to clean it all out. There is no sign of a spring. Is it under the steel disc with a small hole in the center or on top that disc? The two brass contacts that are bent over on the end, one on each side, are in good condition. (they hold the disc centered in the switch) I will try to get the disc out today to see what is under it. I have been searching the internet for a 1 inch dia. water-proof rubber covered switch that is normally closed but as yet no luck. Venturing on, Rich
