hey everyone new to the forum here looking for some help. 1989 evinrude 9.9 e10rces, i was cruising around with my friend and his son and stopped to get some weeds off prop. when i went to restart, the pull rope came out and did not retract. luckily motor started. i found out the the spring had not broken but the end that sits along the edge the pokes out and hooks to side of case had slipped into the case. so i took it apart and was able to pull the end of the spring out and hook it back on. so i bolted the starter back on and now when i fully tighten the bolt in center the rope is very hard to pull and gets easier as i loosen bolt. i took it off and put in on a million times it feels like and nothing ever changes. there is a notch on the bottom that i have been lining up with the hole behind the threaded one but still same result. is there something im missing? any help i would greatly appreciate! thanks
