Re: Mercruiser Throttle ? Increasing and decreasing
It doesn't matter, low or high. You just notice it more at a high RPM becasue it jumps up 400 or 500 RPM really quick
trashman83
This may or may not be relevant, but I had a similar issue many years ago with my first boat. This was an outboard, but the cause would apply to an I/O.
From the time I bought the old crate with her sixties vintage Evinrude, it ran on three of the four cylinders. And, as I was new to boats and to four cylinder engines, I didn't realize it until one day it began to quickly accelerate momentarily - off and on - as the fourth cylinder would occasionally fire for a few revolutions. Sounded different too at those moments.
I eventually figured out that I had one plug fouling almost all the time. Conversion to a different plug type and an electronic ignition cured it. It acted just as you describe here. Sudden accel and decel with no apparent cause.
If you don't have something going on with your fuel system (carb or injectors) I would look for a misfiring cylinder coming in and out.
