Re: Adding oil to power trim & tilt
If it is like my '98 Johnny, tilt it all the way up and with the boat level, remove reservoir cap and fill with Dextron II ATF. If you need to bleed it, fill it, cycle it down and up and leave it up for 5 minutes to allow air to bubble out. Refill and repeat sequence several times, until no more air is present.
