rebelscout
- May 16, 2006
- 6
I just hooked up a used Stringer 800 today and ran it using the garden hose cooling method. I removed the oil level plugs and this is what I found (see pics). Any opinions on what you see?
some have also mentioned that Home Depot has the right size nylon washers in those self serve bins in the nut and bolt aisle.
an extra step required for pressure testing a 400 or 800. You'll need to take a few feet of 5/8" heater hose and slide it over the bare cable end of the shift cable. Clamp it to the cable and clamp a piece of dowel or bolt in the end of the hose as the shift cable acts as a vent for the lower.
no, you don'tDo you have to take the outdrive off to pressure test the upper?
