Re: first time Carb Rebuild any Pointers
If your carb has welch plugs inside covering your high speed jets be aware that the new ones are going to seem too small when you stick it in the recess. I was sure the marina sold me the wrong kit after I opened it. They even couldn't tell me what the problem was.
After I drilled out one of the welch plugs to clean out the chamber area for one side of the high speed jets on my 4 cylinder, it seemed like the new one was too small. I and they had no idea that plug has to be flattened out with a hammer and a punch, when in the recess, and in so doing makes a tight fit.
Also use lots of compressed air after dissassembly. And only replace stuff that has replacement parts in the kit.
