tankerjock
- Apr 10, 2007
- 5
Boat is a 2001 Starcraft Fishmaster 196 with a Mercury 115HP Saltwater Fourstroke. Wife was out on the lake yesterday and the boat wouldn't start after shutting it off to switch tube riders. I got out there and checked fuses, wires, etc. Suddenly it worked again without any real fix that I could say I'd done. Back at the dock I started it four times with no trouble, the fifth try-no start. Again I tried Ignition Switch, Kill Switch, Throttle in idle, wiring, fuses, etc. Nothing. A friend came by later and did same tries and it started. This afternoon I hit the Kill Switch and Ignition Switch with WD40 thinking it may be corrosion. The boat started and idled fine. We cast off the docklines and pushed away, but as soon as I touched the throttle the engine died and it won't start again.
I have power to the accessory switches and depth finder, so I know power is getting to the console. I do not have engine guage power or power tilt-trim, and the engine won't start. After the engine died today I sat in the boat and turned the ignition key to "On", but not "Start", and tried flicking the Kill Switch up and down multiple times-Nothing. I then tried running the throttle out of the idle detent back and forth many times, and once I did get a quick movement of the console guages. I'm thinking of pulling the throttle quadrant off and taking a look to see if anything jumps out at me, but could use any help available.
Thanks for reading.
Thanks for reading.
