I better ask before I bolt it all in.
What kind of lube should I use on the O-Rings around the head bearing assembly at the top of the engine?
Should I use a "gasket maker" like Permatex Grey when I bolt that head bearing assembly back on?
I assume I should coat the roller bearings in the bearing head with moly grease before securing, correct?
