I finally have a new tach and can ask prop questions. I have an aluminum 3 blade 15x15 on a 1999 Evinrude 150 Ficht Ram that does 36 MPH at 5000 RPM. This is on a 19.5 foot 1988 Sunrunner that has had the I/O removed and the motor is on a pod that was added to the back of the boat. Because of this, the boat is off center. I have cured some of the porpising problem by adding smart tabs, but would still like to push the stern a little more out of the water. I have also read that 4 blade stainless props are a little better on gas and make for easier handling at slower speeds. Any suggestions as to what prop I should be putting on this motor?
Thanks
Thanks
