Hello, we have just bought a 1990 Bayliner 1800 Capri that has a 90hp Force/must be older because it is still a US Marine, outboard... The guy had it hooked up to muffs and the motor sounded good when I bought it, took it out on the water for the first time this past Saturday and Sunday, and I am the slowest boat on the water..... Definitely an issue here.... The boat will start up right directly after 3-4 primes and 1 choke on the 1st start, it idles great in neutral but does not get high RPM'S.... when I shift from Neutral into gear, it wants to die unless I throttle a little hard... When we first came out of the NO WAKE zone, I wanted to open it up for the first time, I hammered the throttle forward and we hit a whopping 2500 RPM's and we never got over 2700 RPM's, it also seems to get better throttle in reverse, I am getting passed by heavy boats with smaller motors, I am mixing 50:1, I have not checked spark or compression, but I did pull each plug wire while underway and lost power on each cylinder(3 cylinder)... Although my wife is content with the 90hp "trolling" motor, I think her, my son and I all agree it would be nice to have this boat running at full potential... Any help would be greatly appreciated... Thank you! ~Mike
