Well, thanks to google this boat-newbie found your amazingly helpful forum. What google could not help me find was helpful advice for my issue.
I recently acquired an older boat (a 1970-ish 20ft fiberglass bayliner that was converted from an inboard to an outboard at some point) at a price too good to resist and have been fixing it up for about three weeks now. Yesterday was my first day-trip out of Whitter and considering I have no boat experience, don't know anyone with boat experience and the vast majority of my knowledge comes from one charter captain I had a couple conversations and google I'm not too sure what to do about the trouble I've discovered.
The engine (a 1993 115 Mercury) seems to run very well after a bit of warming up, it died once on the water and that was my fault entirely. The trouble is, the round trip I took was about 16 miles... the engine burned through at least 20 gallons of gasoline on the trip, running at full throttle or near it, during the majority of the traveling. That is abysmal.
As far as I could tell there was no leakage anywhere of fuel, no "glaze" on the water, none in the hull. I'm fairly certain the compression was good but I will be double checking it again. I'll admit, the previous owner said he had the RPM worked out but now I doubt him. I've started looking into RPM things but any helpful advice would be appreciated.
Other than that, I'm not sure what to do. Apparently googling "Poor gas mileage" on anything boat related produces a resounding "No Duh," which I knew already, but as far as I can tell the full throttle MPG of these motors should be around 11 mpg? Or am I mistaken? I know I can throttle down a bit to save some fuel (this was a test run after all) but I'd rather try and solve the issue.
I don't even know where else to began on this. I guess I'm still in shock.
