Aq125 timing
singledoubt88
I have an aq125b that I am trying to set the timing on. The problem is when I check the current Timing with with my light it reads around what looks like 50* at idle. My manual says it should be around 6. I have an Adjustable gun that allows me to advance and it says I need around 45 * more.
I'm lost as to what direction I need to go in now. Any help would be appreciated!
Nhpatriot
Re: Aq125 timing
Something doesn't sound right. I doubt it would run 45 degrees out. Are you sure your on number one cylinder?
singledoubt88
Re: Aq125 timing
I double checked to make sure I was on the number one cylinder, and I was. In fact all cylinders were about 40-45 degrees out. My light also shows a misfire as in an unsteady blinking. Just changed out the coil before the check. I am waiting for an electronic ignition conversion to arrive in the mail. Any sugestions as to what this problem indicates? Thanks guys!
Nhpatriot
Re: Aq125 timing
How do you check or know that other cylinders are 45 degrees out?
singledoubt88
Re: Aq125 timing
With my inductive timing light clamped to each spark plug wire individually the mark on the flywheel is sitting an inch past the 30 degree mark. I have a gun that allows me to adjust spark advance. In order to get the mark to align with the reccomended 6 degrees, I have to advance the gun setting 45 degrees.
Nhpatriot
Re: Aq125 timing
But the mark on the harmonic balance is only good for #1 cylinder.
Nickypoo
Re: Aq125 timing
What's your RPM at "idle"?
If you have access to a standard timing light without adjustments then you may want to use that to check against the adjustable one you're using now.
singledoubt88
Re: Aq125 timing
The electronic ignition came in and got that put on now I am getting good spark across all cylinders. I set the timing to 10 degrees at idle. It idles very well and gets on plane nicely. All is well until I accelerate past 3/4 throttle. The engine surges like it is starving for gas and bogs down. Some background info,
I have changed the fuel pump done a carb rebuild and added a fuel water separator as well as drained old fuel and replaced it with fresh fuel. Any suggestion on what the surge might be?
Thanks fellas
