1988 Liberator with OMC RPM and Prop question
dellsboater
I have a 1988 OMC Cobra Drive, 350 Chevrolet. It Idles fine and the tach reads 800-1000 RPM's.
At 35 MPH at plane it reads 4000 RPMS, but at WOT it Reads 5900 RPM's at 52 MPH. That tells me I should run a 25 pitch prop not the SS 21 I have now. Taking into account each prop pitch increase lowers RPM's by 200, that should put me at 5100 RPM's and more top end. The specs say it should run at 4600-5200 RPM's.
So It seems either I am under proped, or my tach is faulty. I did restore this and replace the tach, but the idle does seem correct. It runs about 140 degrees at 35, but does go to 180 when running wide open and doing some quick turns. It does come back down to the 140 range when running around 35 MPH, and when in no wake areas runs even cooler.
Any advice appreciated
Tail_Gunner
Re: 1988 Liberator with OMC RPM and Prop question
Really need to check the tach...i cant see a 350 reaching 5900 the engine or cam just runs out of steam that high..Or you way under propped and a 21 is a big prop for 1.5 gearing with a 350...Check you gearing though it could be 1.9 i guess
dellsboater
It runs about 5400 rpms at wot with trim down, when I trim up goes to around 5900.
Tail_Gunner
Post back the gear ratio on your drive...I have a freind with a new 350 kodiak (350hp) in the same boat and it struggels to make 50 libs are heavy deep boat's again i think your tach is off and your drive ratio will show that.
