Re: rotten floor replacement options
Lonnie, keep in mind that the deck of a toon is a major structural ellement of the boat and there is a reason you can't find many substitutes, going lighter and maintaining the same strength means going with a composite which also means big dollars.
You really want to go with the 3/4 marine ply, you can use regular 3/4 plywood but it needs to be glassed in so it last more than 3-4 years so the time to cost ratio is about the same, the plain ply is cheaper but all the work and expense to glass it make it a draw.
Once you strip this boat down, redeck and reassemble it you will be glad you listened to all of us at iboats and went with the marine so you don't have to do it again for another 30 years.
