Paramedic2244
- May 22, 2012
- 2
i have a 1978 thundercraft that has a 305 in it with OMC drive. The original block has a crack in cylinder 5. I bought an 87 GM truck 305 block, bored out at 40 over and planned to swap. When i went to put the flywheel from the 78 engine the flywheel hole mount is much larger and the bolts do not line up, subsequently the tourque coupler also does not line up of fit in the flange. What are my options as swapping the crank is not an option either do to rear seal?
