Gear lube leaking from water intake Mercruiser/Alpha
reggien
:confused:Gear lube leaking from water intake Mercruiser/Alpha this is 2nd seal under the impeller it leaks when it sets after a long run on the trailer and the 2nd seal is the high performance one that bolts down
Bt Doctur
Re: Gear lube leaking from water intake Mercruiser/Alpha
? there are no seals under the water pump that "bolt down"
possable areas:
driveshaft seal
shift shaft seal
waterpump base seals 2
reggien
The shop that i take it too put on the high performance one that bolts because this is 3rd 1. so took the drive off this sunday and the pump and it look like that seal got damaged by the kepper for the water pumpoutdrive seal.jpg
reggien
o and it is the base seal the tech drilled and tap it
thanks for your reply
ktbarrentine
This looks similar to the issue in this thread (early last year):
http://forums.iboats.com/showthread.php?t=456259
Don't know how that one came out. It kinda just trailed off with no resolution. Interesting, none-the-less...
Seal PA6-33G looks to be an aftermarket replacement for parts 807929A1, 26-16977, and 26-89238. Any stories on this?
reggien
Seal PA6-33G looks to be an aftermarket replacement for parts 807929A1, 26-16977, and 26-89238. Any stories on this?[/QUOTE
so my ? what would make leak for this seal
ktbarrentine
If the correct replacement seal kept failing, and this aftermarket high performance seal was installed and now it is damaged, you need to track down the root cause. If it is the "kepper" for the water pump, that is a bit suspect because that part is static (does not move), unless there is a stack-up clearance problem, in which, then you probably shouldn't be using this different seal. I suspect a shaft problem (grooved, nicked, or excessive runout). Might be a combination of both problems. Can you get some good close up pics of the shaft, and of that "kepper" (faceplate?)you talk about on the water pump?
Edit: I just found this on line.... for those who haven't seen one before (like me). I wonder how many people use them with success in an application that it isn't designed for?
http://www.mymarinemechanic.net/servlet/the-3569/Driveshaft-Oil-Seal,-Carrier/Detail
oh, and here is the service bulletin that installs this seal. Looks like it is indeed for an outboard (Mercury 3.0) Plus, you need extra new stuff besides the carrier itself to do this install on the outboards. HTH...
http://marinepartsexpress.com/Merc_...Oil Seal Carrier Kit Bulletin No. 2007-06.pdf
Maybe this thing just doesn't mic out correctly, either at the seal itself, or at the o-ring.
reggien
thanks for the info i found out that my upper unit had a pinhole in the case so i out it welded work great :)
