Ran fine last year but can't get it running this year.... It turns over but won't start I drained the gas and put in new gas and changed the spark plugs! Please help
Do you have spark, dose it want to start or dose it just crank. I would start by checking if it has spark, if not check your safety switch where your lanyard to the key goes. make sure it is in nutral. If you have spark then check your fuel pump then your carbs.
