I have a 1988 Mercury 35hp 2 cycle outboard. I replaced the water pump impeller and the engine still overheat and no water comes out of the tell-tell. I pulled the lower unit back off and noticed that the little cup that the upper end of the water pipe fits into is very loose, it appears to be only attached by a screw on one side. Is this normal?
