Re: Mercruiser 5.0 no holeshot/stalls
So, I rebuilt the carb. It really wasnt that dirty. The check ball for the acc pump was corroded pretty bad. I put it all back together and it wouldn't holeshot or run above 2400 rpm. So I dissassebled it and, looking at a parts diagram, realized I was missing the power piston spring. I assume it was there before I disassebled it the first time, and that it sprung itself somewhere. Bought a new one that is supposed to be specifically right for this setup, installed it and it is running better, I do have power throughtout the whole range, but really no holeshot (it backfires and falls on its face and doesnt recover unless I pull the power back). I had set the idle mixture presets at 1 1/2 turns per several sources, and found that it was dying sometimes when I put it in gear. One source said to set them at 3 turns, so I did that and set the idle rpm once is was warmed up (thermostatic choke not affecting rpm), and now it goes into gear nicer (at a better idle rpm now) and doesnt die. This has helped the holeshot some too. Still, not right though.
On a sidenote, (or could this be the problem?), every time I go out it runs the battery down and finally the engine dies and wont restart. I installed a second battery with a switch, which helps get home, but doesnt solve the running batteries dead problem. If the engine is running, and I switch from one battery to the other through the no battery position, the engine dies (shouldnt the alt provide enought power to keep the engine running?) Voltage on the gauges shows 12 and drops to bout 10 1/2 by the time it dies. Then there is jus not enough power to turn it over and start it. I took the alternator into a local electrical shop that seemed familiar with the design and they tested it and said the alternator is good. I have good continuity from the ground wire that goes to the alt to a ground on the block and from the orange positive wire that attaches to the alt to the post on the starter (there is not fuse on my setup).
Question? 1 Can a alt that is not charging, affect holeshot (Im thinking timing advance)??
Question 2 How can I test any further to see if the alt is producing power, (with a simple multimeter maybe?) with it installed on the boat?
Question 3 Can I test the two other wires that come to the alt (alt sensing and excitation) for continuity?
Moderator: Should I start a new thread on this? (I guess thats question 4 really)
Thanks for all the help!
