we are in the process of redecking our pontoon we would like to use Advanteck plywood and Kiwigrip can we use evercoat
marine laminating resin to seal the plywood
If you do you will need to use 1.5oz CSM(Chopped Strand Mat) Polyester Resin without glass is useless. It will crack and allow water penetration. If you don't want to use glass then you need to use epoxy. www.uscoposites.com is a great online resource for resin products.
