rhillman75
Thread starter- Joined
- Jul 28, 2010
- 176
Still can't figure out my "mystery" drive oil leak & resevoir mixing with water.
So I talked to the marina that pressure tested the outdrive over the winter and told him that it is "still" leaving a puddle of drive oil on the ground from the front of lower housing. He still stands strong saying that it "passed" a pressure test after he replaced the shift shaft seal. I also told him that I am getting a "mix" of water in the resevoir tank and now one in the bilge. I am sure the oil in the bilge is from the fitting on the transom, condsidering the line from the resevoir to the fitting was replaced last year. I know he did do a pressure test because he left a plastic fitting in the lower unit just in front of the shift foot. Should that fitting be removed and if it is still in there, then is that where the water is coming in to mix with the resevoir. I also have noticed oil/water mixed lube draining from the weep holes on the lower unit. Trying to figure where to start before I take it back and it is something I can fix rather than getting nailed for another $250.00
