92 Bayliner with alpha 1 mercruiser in/out board stops going while 3/4 throttle
bwest
Going across the lake this weekend at about 3/4 throttle. The boat starts acting like it is cutting out. Lower throttle, seems to stop. Push throttle forward and worse. Then, makes zing sound and completely stops going forward. Tried putting in gear to go forward and it kills the engine. Tried forward two more times with same result. Tried reverse and same thing. Any suggestions?
Re: 92 Bayliner with alpha 1 mercruiser in/out board stops going while 3/4 throttle
Ayuh,... Welcome Aboard,... Sounds like Crud in yer fuel,.... Check, 'n change yer fuel filters....
bwest
Fuel does not seem to be the issue...had upper gears replaced two years ago. Could it be lower gears or lower shift cable? Can the lower shift cable go out while moving like that? I've heard it can from some people, and others say it only does when starting out.
Ayuh,... In yer 1st post, it Sounds like the motor is cuttin' out....
Now yer sayin' the motor is runnin' all Right,..?? but yer loosing thrust,..??
bwest
boat was running perfectly fine...going across lake at about 3/4 throttle...starts acting like it is cutting out...let throttle off a little and put back on..acts like worse...makes zing sound and the boat no longer goes anywhere. The boat is still running...try to put in gear and kills the motor...starts first crank and idles fine...try to put in gear and kills engine...does this twice in forward and reverse...shut boat off and someone tows us back to shore.
Ayuh,... So pull the drive, 'n see what broken...
