I have an '84 mercruiser that I have been having some restarting problems with. The engine starts without much difficulty when cold, however if I run it for 20-30min and then shut if off, I many times am unable to get it restarted before my battery gives up. I will be replacing the battery in the next day or so, but was wondering if anyone else has had this problem. Could it be an alternator problem, that the batter would not have the power to crank after running? Gas line/Vapor lock? Any suggestions? I recently overhauled the carburator and I have cured the hesitation/acceleration problem that I had previously noted. I disconnect the battery after every use or I will often find my battery drained and unable to start the engine.
