shovelhead82
- Jun 28, 2010
- 12
Hello, any help here would be GREATLY appreciated. I bought a used 9.9 and believe it was running well last time the fellow used it. I did not attempt to run it until about 4 months later ( now) but I believe the carb was drained correctly. The motor may not have been run the season prior, not sure. Anyway the seller included an old plastic tank and fuel line which seems in good shape. He did replace the fuel pump and I checked the screen, clean as a whistle. I am a mechanic of sorts(motorcycles) but know little about these engines and they seem rather mysterious compared to my old bikes. Yesterday I started the motor in a barrel, after setting up the 50/1 and priming the thing it started right up. The problem is I only get an idle and very slight acceleration, it will not rev at all but will sit there idling forever if desired. I pulled the cover and ran it observing all. The armature plate moves as intended I believe and I can not see any issues. The one thing is the fuel line connection at the tank seems loose compared to the connection at the motor but I seem to get decent pressure squeezing the bulb. I am considering first getting a new tank and line tho I don't want to spend the $. Next pull the carb apart but hope not to have to. Maybe I'm missing something....I did get an original manual for this machine which is great.
Thanks in advance for any words of wisdom....
Art
Art
