1979 228 tilt trim problem
mikey2463
The problem I am having is trying to raise drive.When either trim switch or trailer switch es are pushed the motor labors for a couple seconds then stops.If I wait a few seconds it will go up a little more than stop again.I was able to get the drive all the way up eventually ,but think the brushes may be bad.
Re: 1979 228 tilt trim problem
Ayuh,... Welcome Aboard,... My guess is ya need a new pump motor, or complete new pump assembly...
