Re: Gm hei
have not really been a fan of points since like 1974 (and yes , i still have my dwell meter from HS).
Great system, being working well with very little change since the dawn of time... But I agree with you, they are old hat now and break-less if a far better system.
dpatzari said:
looked at pertronix conversion. but asked myself this question...
Probably the best choice out there...
dpatzari said:
I buy the module conversion.. etc and put it in an old distributor and what do I have ? .. an old distibutor with a pertronix module.
How perceptive of you....
dpatzari said:
a new HEI with a similar advance curve would be the BEST solution automotive or not.
Err,
NOT!!!
There is far more to a 'Marine' distributor than the label that says 'MARINE'... Different advance curve, only mechanical advance, and here's the biggy.... spark-proof... Those little gauze 'plugs' you see aren't there for decoration... Neither is the seal around the cap and the gauzed vent in the cap....
Put an automotive dissy in and you WILL be sitting on a floating bomb... and I'm not sensationalizing it... I've seen the aftermath of a boat going up... Not pretty, but the guys on board got lucky... They survived, but are wheel-chair bound for the rest of their lives!!!
Chris.......
