Replacing spark plug wires 70 1150, will auto plug wires work?
hoosiercaver1
Hi my plug wires were original kiekhafer plug wires and they were pretty cracked and rotted. My neighbor gave me a set of plug wires from a Chevy hei ignition. I wondered if they would work if I got some threaded ends to crimp on or of I need outboard specific plug wires. I was having trouble starting motor when hot so I want to rule out ignition as a problem. Runs great cold till I shut it down and it sits for 30 min to an hour.
Wingedwheel
Re: Replacing spark plug wires 70 1150, will auto plug wires work?
Those won't work as they are a resistor core. You need to use a wire with a zero resistance conductor. If you have to make a set you can generally buy lengths of wire from your local lawn-mower shop.
hoosiercaver1
Ok thanks for the heads up I wanted to check before I wasted a set of threaded ends on them. Just so I know could u explain why they r different. I understand the concept of less resistance, but I don't get why a auto plug wouldn't need a zero resistance wire too.
Wingedwheel
I think it has something to do with the radio interference they caused back in the good ol' days. I don't know if that still applies with today's electronics, but that's why they do it.
Chris1956
The original Merc wires were stranded stainless steel. Automotive wires are radio-suppressive, and made of some powder conductor. They are unsuitable for outboard use. Try Vintage Mercs dot com for your new plug wires. They had a good price...
hoosiercaver1
Ok, I found a Sierra kit 18-5225 that comes with marine grade copper core wire, the screw in crimp ends and coil and 90? spark plug connectors. I gave it ordered and it should be here this week.
