I have a 97 Maxum 1750NB 3.0LX Merc I/O. It's a good boat. Though not the fastest on the lake (Eufaula and Keystone Okla), it is one of the most fuel efficient. I can run all weekend on way less then a half a tank of fuel. Anyway, it had a couple soft spots in the deck. I cut out the soft plywood to the nearest joint, and patched it back in with a measured 1/2" good quality (several laminated layers) plywood. The foam underneath was dry and firm. I painted the exposed foam with an exterior grade latex paint to hopefully prevent it from taking on water.
I also removed the factory fiberglassed in seat bases with the intention of going ahead and adding another layer to the deck, captains chairs, and the possibility of doing away with the engine cover and building an enclosed rear bench engine cover. I guess my question is, will the revamped seating add too much weight, should I double deck and glass the floor, or just reglass the patched floor, and should I put carpet back in or use some type of coating? Thanks for any input
