I repaced the exhaust manifolds thinking they were the culprit. Still overheats. Took the impeller out so I could run my muffs on water directly to the engine but the water at the t-stat housing is sparse. Can the hose inside the gimble housing or the hose inside the boat corrode to the point it will block water? I'm stumped. Thanks for any advice.
