Went to take our 2007 Starcraft with a Mercruiser 4.3, Alpha One Sterndrive out yesterday and when we got to our storage unit there was a puddle of drive oil underneath the boat drain plug. I looked in the engine compartment and there was a puddle of drive oil in it as well. The drive oil resevoir was empty. Cannot see any leaks visible. I checked the bottom of the resevoir for cracks and followed the line to where it connects to an elbow that goes to the outdrive with no luck for any signs of leaks. I refilled and ran it for the day and had to refill it twice. The uper unit was serviced and an engine oil change about a month ago and this was its second trip out. There was a little oil in the engine compartment when we ran it thefirst time, but I thought it was leftover from the oil change we had done then, but now I'm thinking a seal was not properly installed.
Any thoughts on what might be causing this leak?
