Hey everyone, I just purchased a 1992 Evinrude 15HP E15RENM. It has trouble 50% when I shift into drive/forward. The motor will just stall immediately once put into drive. This only happens 50% of the time and does NOT do this in neutral or when shifting into reverse.When it does go into drive (and not stall) it kind of bogs down for 0.5 second. The boat halls *** on the water with this motor but the only issue is when shifting into drive...any ideas? The previous owner said they did a carb rebuild and today, I changed out the plugs, gear oil, gas, gas tank, and hose. Any help will be greatly appreciated thanks.
