Bought a '81 9.8 hp Mercury I've been fixing up. It's getting close to running how it should but I still have one problem.
The motor runs fine at idle to half throttle. If I give it much past half, it dies on me and is difficult to restart (requires starter fluid). I haven't pulled the plugs and looked at them when I've been on the water, but based on looking at the plugs after running it in a bucket, one of the plugs seems to foul slightly. One of my friends said it sounded as if I was having weak spark. i.e. the spark is enough to fully combust the fuel that is delivered at lower throttles but when you open it up, it floods it out.
I'm trying to take a look at my ignition system, but it seems really strange (see attached photo). It looks like each cylinder is fired by a completely separate coil. The ignition wire running from "Coil A (Right)" to "Cylinder A" just barly makes contact with "Coil A (Right)". I looked inside where the wire plugs into "Coil A *" and it is just a flat piece of metal in there (Nothing for the ignition wire to mate with).
Can anyone tell me if this ignition system is wired correctly? How to test if the spark is strong enough? Or direct me to good resources to learn about these types of ignition systems?
