What kind of bowrider do i have?
freddy112
It's from 1977 and is between 18 and 20 feet long and is an inboard. I don't know the model name or any of the specifications for it. It looks similarly to this boat. I found the picture on craigslist and couldn't find the model name on google. 5L55Id5F13E63Gc3mfc6j8cefa18ce2821854.jpg If you also have an owner's manual or any specifications about it you post that would help a lot, thanks.
Bob_VT
Re: What kind of bowrider do i have?
Welcome aboard.
Look for the HIN Hull identification Number which is normally molded into the transom
The first 3 characters (letters) are the Manufacturer Identification Code then llok that code up here http://www.uscgboating.org/recalls/mic1.aspx and use the MIC section to input those three letters. That will start you on your journey ;)
It's from 1977 and is between 18 and 20 feet long and is an inboard. I don't know the model name or any of the specifications for it. It looks similarly to this boat. I found the picture on craigslist and couldn't find the model name on google. View attachment 155440 If you also have an owner's manual or any specifications about it you post that would help a lot, thanks.
Ayuh,... Welcome Aboard,.... What does the registration say it is,..??
Augoose
My guess is an old Caravelle?
jestor68
The capacity sticker on my boat(s) has the name of the manufacturer on it.
MH Hawker
I cant belive you bought it with out know what it is.
