Hi,
After much reading I have done a diagram of the proposed wiring setup for my boat. Could someone on this forum, more knowleable than I, take a look at it and tell me if there are any issues with it. Have I got everything right or should I be adding more equipment to it? I have not yet worked out the wire sizes and colours as yet. Nor have I worked out what size fuses I will be needing. I'd just like to know if I have the connections of the wires right. The boat engine is a 2qm15 Yanmar diesel. I don't know what amp hours my battery is rated at, but it's a 12 volt Seamaster M70 (CCA 660).
P.S. In my wiring diagram the two words "Com" and "Off" were not meant to be there and should be ignored.
Thanks,
bluey.
Thanks,
bluey.
